Cellulose Blown In Insulation Questions... - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-29-2010, 04:59 AM   #1
Question
Cellulose blown in insulation questions...
I live in NE Ohio. I am refurbishing an old house with balloon costruction. the house had lathe and plaster which has all been removed so I can install new drywall. I am down to studs in all rooms.... so here are my questions:
1. Do I hang plastic as a vapor barrier then blow in the cellulose insulation so I can see it fills properly, or hang plastic vapor barrier then drywalll followed by insulation.
2. Do I need to worry about taping off plastic electrical boxes in the walls. Also what do I do around the light fixture boxes in the ceiling above the second floor which I want to fill with 15 inches of blown in cellulose?
3. What other issue do I need to worry about?
Thanks for your replies. I will be starting this process as soon as this afternoon.
1eagertolearn is offline   Reply With Quote
Old 09-30-2010, 07:32 AM   #2
Rewards Points: 5,336
The insulation that's blown into an open cavity will stick to the surfaces in the cavity. They should then shave off the excess, even with the studs. The vapor barrier would be put on top after the insulation is in place. They might have you wait a while to install the plastic as the cellulose might have some moisture in it.
They have plastic "pockets" you can get to go behind the wall and ceiling boxes that will be taped to the vapor barrier to seal the room. These would get installed before the insulation.
Ron
Old 09-30-2010, 07:58 AM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 304
On your exterior studs make sure all the nails are pulled on the surface or driven in flush. They just blow the insulation into the stud cavities then with a viberating tool smooth the insulation down flush with the front of the studs. You must have your sheet rock in place on the ceiling so they can blow it in from topside. If you are having any insulation blown in any interior walls there must be sheet rock or what ever wall covering you are using, in place so there will be a stop for the insulation other wise it will just blow through the walls.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 10-01-2010, 11:42 PM   #4
Registered User
Rewards Points: 5,498
http://www.cellulose.org/HomeOwners/...orBarriers.php
Check with your local Building Department.
Are you going with wet blow-on cellulose, dry- in wall, or dense pack in netting or wall covering?
Gary
Basement insulation / vapor barrier questions deepstuff Building & Construction 16 02-09-2012 09:11 AM
Some questions about attic insulation and improving it. Mister Sonny HVAC 5 06-29-2010 10:00 AM
Removing old attic blown in insulation and 52Caddy Remodeling 12 03-27-2010 11:19 PM
Has anyone used Green Fiber blown in insulation? pomelo Building & Construction 7 02-10-2010 07:17 AM
Basement Insulation Questions? BobR General DIY Discussions 1 09-30-2008 09:25 PM
