Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 09-11-2009, 02:27 AM   #1
PDX_Gal
ceiling options for 30" o.c. rafters
I'm finishing an unfinished upstairs room in my 1 1/2 story house, built in 1920. The rafters are 30" o.c. Originally they were 2x4, but I had them sistered with 2x8s for extra strength and to accommodate R20 insulation. The plan is to cover the rafters as is, for a cathedral ceiling.
I planned to use 5/8" drywall to finish the ceiling. However, USG states the maximum spacing for 5/8" sheetrock is 24" o.c.
So....can I get by with using 5/8" drywall and hope it doesn't sag? Maybe add some blocking between the rafters for additional support? What other options are there?
Thanks for any ideas or stories of your own.
pdx_gal is offline   Reply With Quote
Old 09-11-2009, 07:05 AM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
What kind of insulation did you use? With 30" on center spacing. You could install 1x2 or 1x3 16" oc perpendicular to the bottom of the rafters, this way you could use 1/2" drywall.
Old 09-11-2009, 10:06 AM   #3
Drywall contractor
"Strapping" with 1"x's as Bob suggested would be your easiest solution and 1/2" is acceptable.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 09-11-2009, 12:47 PM   #4
PDX_Gal
Buletbob and bjbatlanta, thanks for your helpful advice. Sounds like consensus. The insulation is fiberglass batts, which I can pretty easily shift a bit to nail in some blocking or "strapping" (a new vocabulary word for me). So will do that. And thanks for the tip on using the 1/2" then instead of 5/8"....will save some $$ and be easier to handle. This forum rocks!
Old 09-11-2009, 01:01 PM   #5
Xtreme DIY'r
The 1x2's tend to split...I've used the 1x3's with better results
Old 09-11-2009, 02:02 PM   #6
Drywall contractor
I agree, and it's easier to hit a wider piece of wood, especially for a DIY'er working overhead.....
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Old ceiling replacement idsp General Discussion 12 07-25-2009 11:48 AM
Advice for installing ceiling fan Ceiling Fan Man Electrical 5 06-02-2009 05:18 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
ceiling options? zel Building & Construction 3 04-12-2007 04:22 PM
