Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 03-03-2008, 11:08 AM   #1
Ceiling Drywall - Question
I know that typically we use 5/8" drywall for the ceiling (which is what I have always done) due to issues with sagging, but how big a difference does this really make? I will be finishing a basement ceiling where the joists are 16" on center...do I really need to use 5/8" here? 1/2" certainly is cheaper and much easier to work with, but I definately don't want to wish I had gone with 5/8" later on down the road.
nthomp16 is offline   Reply With Quote
Old 03-03-2008, 12:40 PM   #2
I have used 1/2" drywall on ceilings with no sag. In fact, it was 4' X 12' -1/2" sheets. I always assured that I fastened it properly with at least 1-1/4" coarse thread screws at 6" to 8" spacing. I did this the first time 26 years ago and the ceiling is still hanging to this day.
Handyman50 is offline   Reply With Quote
Old 03-03-2008, 12:41 PM   #3
1/2" should be fine for 16" OC joists.
perpetual98 is offline   Reply With Quote
Old 03-03-2008, 01:01 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Use 1/2" with 16" OC framing. It WILL NOT sag. guaranteed.
Only possible issues would be if the framing is not even. If that is the case, install strapping and furr/shim out, to reduce differences.
- Build Well -
Ceiling Drywall Repair Question kennykenny Building & Construction 6 12-30-2007 10:18 AM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 04:00 PM
Drywall Painting Question WorkOnIt Painting 8 06-14-2007 05:12 PM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 09:52 AM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 06:47 AM
