Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 04-08-2009, 05:40 PM   #1
caulking between backer board and plastic shower pan
I read that I need to caulk between my backer board and plastic shower pan where I left my 1/8 or so gap. Is a kitchen and bath caulk what I should use here? Do I caulk now or after I tile or both? I would think both between the CBU and pan and then again between the tile and pan. Thanks for any help with this, just trying to do everything right and the more I read/learn the more questions I have!
ponch37300 is offline   Reply With Quote
Old 04-08-2009, 10:18 PM   #2
Man of many hats
wrangler's Avatar
Yes. Before and after. The first to prevent wicking, the 2nd for basically the same reason. Anything to keep water from finding its way into the walls.
Man of many hats
wrangler is offline   Reply With Quote
Old 04-09-2009, 05:39 AM   #3
Remodeling Contractor
Final caulking is done after. First fill the tub, so any movement is accounted for when caulking. For plastic tubs or surrounds use siliconized acrylic caulking, not pure silicone.
Old 04-09-2009, 09:22 AM   #4
Thanks guys.
Old 04-09-2009, 09:28 PM   #5
Is the cbu over the flange or on top of the flange?
Mop in Hand is offline   Reply With Quote
Old 04-10-2009, 09:28 AM   #6
I furred out the studs even with the pan's lip and then ran the cbu over the lip as recommended from this site. I had thought about just butting the CBU up to the lip and then tile to the pan but was advised to run the CBU over the lip and down to the pan leaving an 1/8" gap.
Old 04-10-2009, 11:38 PM   #7
good job
butting backer board up to plastic shower pan ponch37300 Remodeling 6 04-04-2009 07:20 PM
Help with bathroom shower tile. dafonz Building & Construction 6 01-06-2009 11:00 AM
Any experience with Dupont Real Touch elite laminate flooring? danidisney Flooring 12 08-24-2008 04:22 PM
