Caulk Or Grout Shower Corners - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-26-2013, 06:19 AM   #1
Rewards Points: 150
caulk or grout shower corners
Ive looked around a bit and it seems most people suggest silicone on tile shower corners. I was curious what you guys opinion was.
Arsinek is offline   Reply With Quote
Old 07-26-2013, 06:49 AM   #2
DIY staff
Rewards Points: 7,174
Walls move--so when grouting--knife out the grout in the corners and apply a good caulk---I use silicone---however many setters prefer the color match caulks that are made by the grout manufacturers---
I've never had a failure with silicone so I have not tried the other products--
Old 07-26-2013, 08:00 AM   #3
Rewards Points: 3,130
I use the color match caulk. To me, it just looks better.
Old 07-26-2013, 08:34 AM   #4
Rewards Points: 150
Any tips for applying the silicone? Ive used latex caulk a good bit but no silicone.
Old 07-26-2013, 11:22 AM   #5
747
registered
747's Avatar
Rewards Points: 534
always caulk when change in plane.
747 is offline   Reply With Quote
Old 07-26-2013, 11:59 AM   #6
I don't know what the pros do, but what I have done the couple of times I've used silicone caulk is to first lay out strips of painter's tape separated by the width I want the caulking to be, applied the caulk, then smoothing it out with a finger that was dipped in soapy water. You have to be careful, as the stuff sticks to almost anything.
Old 07-26-2013, 02:53 PM   #7
Rewards Points: 150
Hmm soapy water. Does that work?
Old 08-22-2013, 04:30 PM   #8
I've recently replaced my master bathroom tub and I just used a caulk gun. It eliminates the mess and doesn't get all over.
MNBuilder is offline   Reply With Quote
Old 08-22-2013, 06:42 PM   #9
Silicon can be removed with mineral spirits..
Peppe1019 is offline   Reply With Quote
Old 08-22-2013, 07:33 PM   #10
DIY staff
Silicone caulk is the most challenging until you learn how----
Here's how----
You need a roll of paper towels and a bottle of Greased Lightning.
Remember this---silicone will stick to any clean dry surface--
It will not stick to a wet soapy surface
Apply a small bead of caulk---immediately spray the line with Greased Lightning
Spray your finger---then tool the caulk with your finger, removing excess to a paper towel.
Try this---it works.
Arsinek (08-22-2013)
Old 08-22-2013, 08:49 PM   #11
Rewards Points: 150
Ya, Im not looking forward to it. Im thinking I should play around with it on some piece of trash or something first.
Old 08-24-2013, 08:16 AM   #12
409 works great for cleaning fresh silicone. apply the silicone before grouting and dish out the joint. allow it to dry and grout over the top. This seals the corner but lets your tile shower have a uniform finished look.
vinceg14 is offline   Reply With Quote
Grout or caulk bathtub tile corners aigsrone Tiling, ceramics, marble 1 08-03-2012 11:18 AM
Grout that was not sealed in shower J187 Remodeling 5 02-06-2012 10:08 AM
Grout or caulk shower? Joe Vieira Tiling, ceramics, marble 5 02-22-2009 10:42 AM
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 09:11 AM
Cracking Grout Between Shower Tiles average General DIY Discussions 9 05-08-2007 02:20 PM
