Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 01-30-2010, 01:55 PM   #1
Chicago, IL
Michael Thomas's Avatar
Caulk 1/4" gap?
After removing the old caulk above a tub, I discovered that there is a 3/16" - 1/4" gap between the bottom of the tile and the tub:
Can I caulk this wide a gap with silicon sealant by using a backer rod, or do I need to first somehow reduce the gap?
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs
Michael Thomas is offline   Reply With Quote
Old 01-31-2010, 06:35 AM   #2
GardenConcepts's Avatar
Caulk 1/4" gap?
Silicone caulk and backer rod is exactly what I have done. Back when green board was used a a tile backer, it was recommended to leave about a 1/4" or 1/2" gap from the tub so water would not wick up into the drywall- the tub has a lip that you don't see, so the water can't get behind the wall. That gap with the tile isn't too bad. If the tile was tight to the tub you might have issues if anything moves/settles.
GardenConcepts is offline   Reply With Quote
Old 01-31-2010, 08:19 AM   #3
Chicago, IL
Caulk 1/4" gap?
Thanks.
Old 01-31-2010, 04:41 PM   #4
Moderator
Caulk 1/4" gap?
Here is the reason for the hour-glass shape of caulk made by the backer rod: http://books.google.com/books?id=fDs...age&q=&f=false
http://www.coastalcontractor.net/article/117.html
Be safe, Gary
Clothes taking longer to dry?
Recaulking at previously silicone-caulked shower door frame hffeagan Kitchen & Bath Remodeling 33 01-03-2013 12:58 AM
caulk question scatterbrain General Discussion 5 10-04-2008 07:57 PM
Caulk Frustration j4ino Building & Construction 5 09-29-2008 08:03 AM
recaulking: cleaning out old caulk questions adamc Painting 6 09-19-2008 06:30 PM
