Carsiding Ceiling - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-17-2010, 05:02 PM   #1
carsiding ceiling
Is it going to work to nail T&G carsiding to a plaster cieling?
ClayFraz3 is offline   Reply With Quote
Old 12-17-2010, 05:43 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
if you install 3/4 furring strips 16''o.c. it will
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
ClayFraz3 (12-18-2010)
Old 12-17-2010, 08:57 PM   #3
Registered User
Rewards Points: 5,524
Keep in mind some older ceiling joists spans were only strong enough for the 8# per sq.ft. plaster & lath weight without adding more. Check the span: http://www.awc.org/calculators/span/...orizontal+Span
Gary
Old 12-18-2010, 09:35 AM   #4
furring strips should be glued and/or nailed?
Old 12-19-2010, 11:16 AM   #5
Drywall contractor
Rewards Points: 1,070
I'd do both if it were mine. Make sure your nails/screws are proper length. I would think an inch into the framing members, minimum, would be good.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
The Following User Says Thank You to bjbatlanta For This Useful Post:
ClayFraz3 (12-19-2010)
How do I get power to a new ceiling fan? sestivers Electrical 15 10-10-2016 04:16 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Normal light fixtures with suspended ceiling? Scott99999 Electrical 9 09-02-2010 04:44 PM
Repairing ceiling Arnold General DIY Discussions 8 09-12-2008 08:13 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
