Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 05-15-2004, 12:41 AM   #1
Carpet Nightmare
Here is my problem. A large bedroom was changed into a small room and hallway, leading to the new addition masterbedroom. This was accomplished by the addition of 2 walls. My problem is that they built the new walls ontop of the existing carpet. the carpet is now over 10 years old and I plan to replace it with a hard wood floor in the small room. To do this, I need to remove the carpet. I have cut the carpet as close to the walls as I can, but still it sticks out about a 1/2 inch. Under the carpet is a concrete slab, not wood. So the board laying on the carpet is probably only anchored to the slab in a few spots. I have tried slipping the carpet out the other side with limited success. Other then tearing out the drywall to cut the carpet closer to the bottom board, has any one any advise on how to remove it. Feel free to email me. Thanks Nomad
The Nomad is offline   Reply With Quote
Old 06-17-2004, 11:29 AM   #2
Mike Finley
Guest
Posts: n/a
Carpet Nightmare
I'm a bit confused that you can't cut carpet closer than 1/2 inch away from the wall.
The base plate of the wall should be above the concrete floor, the thickness of the pad and carpet, why can't you get a carpet blade angled at a 45 and cut the carpet and pad about a 1/4 inch back behind the face of the wall? This seems pretty easy. Any molding will cover up anything anyways.
Old 09-30-2007, 08:54 PM   #3
Carpet Nightmare
I agree. The mobile home industry builds walls this way. It's not easy but it can be cut closer that 1/2" with a standard carpet knife. If you are reinstalling carpet the tackstrip should be set no farther than 3/8" from the wall. The new carpet will be tucked in the gap. covering what is left of the old carpet.
flooring dude is offline   Reply With Quote
Old 09-30-2007, 09:25 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Carpet Nightmare
This post was started over 3 years ago.
- Build Well -
DIY Chair mat from plywood and carpet tiles jbwaechter Flooring 3 08-20-2009 07:29 AM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
Laying carpet for small exercise room J187 Flooring 10 09-30-2007 09:28 PM
Carpet Glued On OLD linoleum-HELP gradlass Flooring 5 09-30-2007 09:26 PM
glued down carpet...can I cheat? Dusty Flooring 3 10-10-2006 06:18 PM
