Capping Windows With Aluminum VS Flashing With Aluminum - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-05-2010, 12:03 PM   #16
no they didn't
I had to tell the guys to NOT put tape on the bottom of the window as that is what Pella says. I have seen the tape done both ways.
scott j is offline   Reply With Quote
Old 02-05-2010, 11:55 PM   #17
Home Performance
HomeSealed's Avatar
Rewards Points: 710
The bottom should NEVER be taped. In terms of top and sides, the OLD way was to wrap the tyvek into the hole, then tape the window flange to the tyvek. Then when people started noticing that tyvek can fall apart over the years, it is now official policy of every manufacturer and procedure that the flange be taped to the sheathing and housewrap goes over it. Anybody still taping to the wrap is outdated and uninformed.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 02-24-2010, 09:49 PM   #18
Recommend
Hi,
do you know of a good company in the Chicago area? thanks
Old 02-24-2010, 10:13 PM   #19
MJW
Actually Tyvek falls apart from UV rays when it isn't covered up quick enough.
The house wrap is our rain shield.
MJW is offline   Reply With Quote
Old 02-24-2010, 11:57 PM   #20
A possible solution ?
It is covererd with siding. Just have to flash the windows properly in the spring.
Which brings up a final question for a solution.
Since my carpenter didn't install the windows properly with the building paper over the top of the windows (he went under and then taped it to the top of the window) wouldn't it make sense to leave it and then flash with aluminum over the top of that?
What I mean is that I don't want to make a problem worse by trying to pull off the tape, cutting and damaging the building paper. Rather, slide the aluminum flashing under the building paper higher than the top window flange. So any water that runs down the building paper hits the aluminum first before hitting the taped window flange.
Thanks,
Scott
Old 02-25-2010, 06:24 PM   #21
Home Performance
HomeSealed's Avatar
Rewards Points: 710
I realize that it is the rain shield, however that does not change the fact that wrapping the tyvek into the opening on all sides is deemed incorrect . Further, I have personally seen siding jobs (not new construction) where the tyvek is disintegrating years later. I can't say the specific reasoning for this, but unless UV rays pass through vinyl, that isn't why. This isn't an isloated thing either, I'm sure there are a lot of other pros who have seen the same.
www.HomeSealed.com
Old 02-25-2010, 09:42 PM   #22
MJW
Haven't had much for wall coverings up here older than 10 years or so. The ones I have seen that were deteriorated were homeowner jobs that took months to get covered.
There is one house down the road from me that they put an addition on 3 years ago. They still have not sided it. You can hardly read the name on the wrap.
The Rep at a sales meeting said that the deteriaration is caused by UV rays and not getting covered. I can't say I have seen any other Tyvek on our jobs that was that way without it being exposed for long periods. Usually it was a slow, incompetent contractor or homeowner. Usually that is why we are there......to fix the mistakes.
Old 03-03-2010, 11:06 AM   #23
Fix and tape Window Flange to Sheathing
So, the question is....do I remove the TAPE on the top of the window, cut just the Tyvek on top, then tape the Window flange to the sheathing? Or just cut the tape and the Tyvek so as not to destroy the Tyvek by ripping off the tape? Thanks
Old 03-05-2010, 05:38 PM   #24
Home Performance
HomeSealed's Avatar
Rewards Points: 710
The proper sequence is : flange caulked to sheathing, tape over flange, tyvek over tape.
www.HomeSealed.com
The Following User Says Thank You to HomeSealed For This Useful Post:
Tom Struble (03-05-2010)
Old 03-05-2010, 06:28 PM   #25
Tom Struble's Avatar
Rewards Points: 2,002
earlier versions of tyvek did break down under the cladding
that tyvek had a very smooth texture, the newer ''improved'' tyvek has sort of a checker board texture and supposedly does not get brittle
Tom Struble is offline   Reply With Quote
Old 03-09-2010, 09:39 AM   #26
Chicago, IL
Michael Thomas's Avatar
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 03-09-2010, 09:46 AM   #27
Chicago, IL
Hi,
At my own properties, I use:
http://www.swistun.com
they perform the highest quality replacement siding jobs I've seen - they are absolutely meticulous in their detailing.
(For the record, my only business relationship with Swistun is writing them large checks.)
Old 04-05-2010, 11:54 AM   #28
Thanks everyone for the comments. Here is the rest of the story:
1) For the new Pella Windows that were not taped properly, they installed a drip cap over the top of the aluminum window cap. I made them tape the drip cap to the sheathing and not the Tyvek. So, if water comes down the wall beneath the siding, it will hit the drip cap first and not the Pella window that is taped to the Tyvek. This was less work than having to remove the Aluminum window capping and filler wood on the top. Luckily, the 2nd floor windows are right under the 2' overhang so I didn't worry about those.
2) For the old windows, those are in the process of being all redone with adding aluminum capping that is flashed on top and caulked on the inside Aluminum capping to inside of window.
I ended up hiring a different siding company to fix the problems.
Old 04-05-2010, 12:19 PM   #29
What about a Deck Ledger Board?
I have aluminum flashing behind the J-Channel / Siding and over the top of a ledger board for a deck(bolted to house). Should that also be taped to the Sheathing? I don't think it is taped to the Tyvek or Sheathing.
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 01:18 PM
Replacing aluminum frame windows gallasm Remodeling 2 01-05-2009 11:03 AM
proper steps in wrapping tyvek and flashing windows?? 4just1don Building & Construction 4 11-17-2008 07:10 PM
Capping for Windows - Purpose? BigJimmy Building & Construction 6 01-03-2008 11:40 AM
Flashing for New Construction Replacement Windows in Stucco House BigJimmy Building & Construction 10 11-03-2007 01:48 PM
