Can't Find Spelled Out House Numbers - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-22-2006, 01:52 PM   #1
I'm looking to change the house number over my garage from 903 to Nine Hundred And Three. (numeric to lettered)
I've Googled my brains out and haven't had any luck finding anyone that does it. There are tons of plaques but nothing with just the lettering.
This style of house numbering used to be common, does anyone know where I can find someone that stills sells them this way?
Pillsbury is offline   Reply With Quote
Old 12-22-2006, 06:50 PM   #2
I haven't seen spelled out numbers for sale anywhere...they used to be on most old houses ...you could try a local ironworks/welding shop..they could make them but it might be cost prohibitive. fyi- a lot of localities require numerals because it's much easier/faster to read by ambulances,firetrucks,police when driving down road looking for an address.
pat11784 is offline   Reply With Quote
Old 12-22-2006, 06:59 PM   #3
joed's Avatar
Rewards Points: 12,008
This place sells the entire a-z alphabet. You spell out your own.
http://www.westonletters.com/index_2...file=index.php
Also found this
http://65.36.132.135/merchant2/merch...ry_Code=SCRIPT
Old 12-28-2006, 07:58 AM   #4
You could paint your own numbers on the house.
Or you could buy some flexible wire and make the numbers to your taste.
redline is offline   Reply With Quote
Old 12-30-2006, 12:56 PM   #5
Thanks everyone for your help. I didn't realize how prohibitive the cost is. Guess I'll just stick with the regular numbers or maybe just get up there with a Sharpie and good intentions (kidding)
Old 12-30-2006, 05:01 PM   #6
How many digits in the house number?
Old 12-31-2006, 08:40 AM   #7
With a router, bit, and a piece of wood, you could make your own sign. Lay out the letter style of your choice in pencil and then cut it into the wood. Paint in the cut out sections and then apply Poly or other weather resistant coating. Probably wouldn't take more than a few hours, including drying time.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 12-31-2006, 03:01 PM   #8
yummy mummy's Avatar
Rewards Points: 1,016
I like your idea majakdragon.
Many in my neighbourhood have the same type of thing, and looks really nice.
yummy mummy is offline   Reply With Quote
Old 01-06-2007, 01:12 PM   #9
Only do it if you don't mind service people not being able to find your house and dinner guest arriving late and pissed.
mighty anvil is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
200 Amp service really needed for a 830 sq ft house? overkill? alexz Electrical 7 11-16-2009 06:54 PM
Older house, no soffit vents- what to do? nebben Roofing/Siding 3 01-24-2007 03:37 PM
Brick and block house footer question. ourzoo Building & Construction 2 07-01-2006 03:57 PM
