Can You Attach Plywood To Cinder Block Wall? - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-22-2012, 09:59 AM   #1
Can you attach plywood to cinder block wall?
I need to attach a sheet of plywood to a painted cinder block wall. The sheet is 4'x5' 1/2"D. I really don't want to have to use a concrete drill and was looking at an adhesive I could use. Any suggestions? drawbacks?
KERMIT7 is offline   Reply With Quote
Old 02-22-2012, 10:04 AM   #2
Rewards Points: 12,880
Not a great idea. No wood except pressure treated should ever come in direct contact with concrete. If you do not use some Tap Cons screws it's going to fall down.
Far better to use pressure treated 2 X 2's on the wall then attach the plywood to the 2 X 2's.
mae-ling (02-22-2012)
Old 02-22-2012, 10:05 AM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Hard nails (concrete nails).
Plywood should be treated.
titanoman is offline   Reply With Quote
Old 02-22-2012, 07:00 PM   #4
Rewards Points: 4,454
i vote for either guy but have always used joe's method to give SOME air circulation behind the ply
Old 03-29-2012, 11:33 PM   #5
Technically it can be done with concrete nails but it's not recommended...
diyjohn1234 is offline   Reply With Quote
Old 03-30-2012, 09:22 PM   #6
Rewards Points: 512
use a powder gun (ramset, hilti) to attatch it
princelake is offline   Reply With Quote
Old 03-31-2012, 02:55 PM   #7
Registered User
Rewards Points: 4,934
As said, the air circulation is critical. Plywood has a low permeability to moisture (0.75), acting as a vapor retarder. P.t. wood wicks water unless you waterproof treat it. Much easier is to just put 6mil poly or Grace ice&water shield on the back of any wood against concrete wall as allowed by code. This will stop any capillary wicking to wet the plywood: http://www.greenbuildingadvisor.com/...-building-code
Number 7: http://publicecodes.citation.com/ico...9_3_sec017.htm
NATURALLY DURABLE WOOD. The heartwood of the following species with the exception that an occasional piece with corner sapwood is permitted if 90 percent or more of the width of each side on which it occurs is heartwood. Decay resistant. Redwood, cedar, black locust and black walnut. Termite resistant. Alaska yellow cedar, redwood, Eastern red cedar and Western red cedar including all sapwood of Western red cedar.
Gary
Gary in WA is online now   Reply With Quote
# of rebar in cinder block wall johnlvs2run Building & Construction 3 08-08-2010 11:48 AM
Tying in a 2"x4" walled-booth with a cinder block wall johnofthemount Building & Construction 3 12-19-2009 03:51 PM
Half-height Cinder Block wall Electrical theatretch85 Electrical 11 04-09-2009 12:49 AM
Cinder Block retaining wall kspencer General DIY Discussions 4 04-20-2008 06:33 PM
Hanging cabinets on cinder block wall ponchoman1 Remodeling 2 04-25-2006 10:34 PM
