Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 03-19-2007, 09:45 AM   #1
Can Structalite be used to set steel compos tub?
We have a Crane San Marcos Armorplus tub, which is Crane's answer to an Americast steel/composite type tub product.
After installation (and they had already started tiling the walls) my husband and I noticed that when you stand in the tub that there is a loud creaking and moaning and noticable flex. Since they hadn't tiled the floor yet we ran a 3 foot metal ruler through the gap under the tub and were able to go all the way to the wall for the full length of the tub--was not set in a mortar bed; tub only supported at ends.
We had a huge argument with contractor who wanted to spray in foam to "fix" the problem. We insisted the tub be pulled out and reinstalled in a mortar bed. He finally agreed.
Now they are pulling out the tub and the tile guy is giving advice to the very young-looking plumbers that they should use "Structalite" instead of a sand mortar (which is what I've read should be used.) Help! What is structalite and is it up to the task of tub setting?? I need an answer fast, if possible, because we are surrounded by fast moving burly contractors now!
House_Amuck is offline   Reply With Quote
Old 03-28-2007, 05:15 PM   #2
Structolite is the base coat under plaster. I've seen plaster used as a base, thinset, structolite and concrete. NOT spray foam.
Ron
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Brick Veneer on steel angle iron sandyman720 Building & Construction 3 07-09-2007 09:21 PM
Pros/Cons of Steel Siding moneymgmt Building & Construction 2 06-19-2007 03:57 PM
A steel building that doesn't look like a steel building? MMW Building & Construction 1 06-11-2007 05:24 PM
Steel Beam or Wood Reinforcement for 2nd floor addition? coralhead1 Building & Construction 2 06-06-2006 02:22 PM
