Can Mud Be Applied After Prime Coat? - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-19-2007, 02:52 PM   #1
Can mud be applied after prime coat?
I have prime coat some of the walls/ceilings... there are spots I would like to feather out more to make it less obvious...
Can I mud a bit at those spots...? just wonder what people usually do at this situation...
I already mud a little bit .... I do not intend to sand those... as they are very thin....
my guess "YES, it should be OK, as long as I only did prime coat, not the final colored coat with egg shell finish"
want to hear what the professional has to say though... what they usually do at this situation... I know, they are professional so they normally won't have this situation.. but just in case there is...
KUIPORNG is offline   Reply With Quote
Old 03-19-2007, 06:58 PM   #2
joed's Avatar
Rewards Points: 11,576
Drywall mud sticks to everything. It can applied after paint prime or finish. You can sand it if you wish. Just apply more primer over the new mud.
Old 03-19-2007, 07:43 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
You can apply compound over finish paint as well. The only difference that you will notice is that it takes longer for the compound to dry than on raw, 'unsealed' sheetrock....
Example of coating over painted walls:
- Build Well -
Can you put brown coat on if it's going to rain? Not Sure Building & Construction 3 03-23-2009 07:57 AM
Finishing Cabinets -- Wow. Need advice! Patriot_RAM Painting 15 08-09-2007 10:55 PM
Round 2 & 2nd coat question usaalways Painting 5 06-24-2007 09:20 AM
fresh sheetrock, prime? jamesdart Painting 3 02-25-2007 07:22 AM
