Can I Widen The Door Jam? - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-13-2013, 12:02 PM   #16
JOATMON
ddawg16's Avatar
Rewards Points: 1,826
To get an idea of what your in for....get a stud finder....see if you can locate the studs on the door frame....
One piece of advice....assuming the electrical is out of the way and you have your header in, make sure you set the door frame with the door in it....it improves your chances of it being straight. Here is a pic of what a rough opening should look like...
Once you have determined what you need to do....get your door along with the frame....then create your rough opening to match. You want a little space between the frame and rough opening for wiggle room. I personally prefer to try and nail the jamb side to the stud and shim the hindge side. But thats me....I've only done maybe 5 doors so I'm far from an expert...but I've made plenty of mistakes....like, making the rough opening 'exactly' the same size as the door frame....
The Following User Says Thank You to ddawg16 For This Useful Post:
rossfingal (01-13-2013)
Old 01-13-2013, 12:06 PM   #17
Rewards Points: 2,238
Find somebody that knows enough about framing/structure to see if the door
is in a "load-bearing" wall.
If you're going to have to do something about the electric -
don't stand in a puddle!
rossfingal
rossfingal is offline   Reply With Quote
Old 01-13-2013, 12:55 PM   #18
Haverhill Trade 1965
Originally Posted by oh'mike View Post
Do not be surprised if you find that the doorway was already framed for a larger door--then reduced to fit a door that the builder miss-ordered---
If it is, don't forget to buy a few lottery tickets before your luck changes.
Duckweather is offline   Reply With Quote
The Following User Says Thank You to Duckweather For This Useful Post:
oh'mike (01-14-2013)
Tags
door framing , hanging doors , widening door jam
how much can I widen a deck? denemante Building & Construction 1 07-24-2012 01:23 PM
Want to widen a doorway. Need advice (picture gallery inlcuded) jderosa3 Kitchen & Bath Remodeling 3 06-03-2012 11:45 AM
Can I widen this crawl space opening? jpearson311 Building & Construction 24 05-04-2012 10:23 AM
Am I allowed to widen my own driveway? Rick2203 Building & Construction 9 07-17-2011 07:31 AM
Widen a doorway Oilerz Remodeling 3 01-06-2008 08:31 PM
