Can I Relocate A Roof Support? - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-10-2017, 10:29 AM   #1
Rewards Points: 8
Can I relocate a roof support?
below is a picture of some roof supports attached to the top plate of a 6" wall between the house and attached garage. I am expanding the mud room and enclosing the space behind it which is part of the garage. can I just relocate the support to a nearby structure or do I need to install a header. the support post fall in the middle of the wall I wish to remove.
rhooten1979 is offline   Reply With Quote
Old 05-10-2017, 03:53 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,632
Re: Can I relocate a roof support?
Ayuh,.... It Appears to be load bearin', so, ya, a header would be necessary,...
Bondo is online now   Reply With Quote
Old 05-10-2017, 04:07 PM   #3
Rewards Points: 8
any suggestions about header construction?
Old 05-10-2017, 04:18 PM   #4
Rewards Points: 2
how many are you moving, if it's only 1-2 wouldn't be a problem, there's plenty of them
ktmrider is offline   Reply With Quote
Old 05-11-2017, 07:57 AM   #5
Rewards Points: 8
Sorry,
I am moving the three located in the bottom left corner next to the dry vent pipe.
one picture shows all and the other show the top of the vertical brace.
Can I relocate a roof support?-roof-brace.jpg   Can I relocate a roof support?-top-vertical-brace.jpg
Old 05-19-2017, 03:55 PM   #6
Rewards Points: 8
the ceiling joists run parallel to this wall so the only thing it is supporting is the roof supports. I would also like to make it a blind header so the ceiling is level all the way across.
Ceiling Rafter / Roof Support ebne0018 Building & Construction 8 03-27-2015 03:46 PM
repairing a rotten support beam for a 2x6 garage roof zamphire Building & Construction 8 01-19-2015 02:26 PM
Garage Roof Support & 2nd Floor Addition Info? olimits7 Building & Construction 3 10-15-2012 06:42 PM
help needed about roof support drake093 Building & Construction 39 09-09-2012 03:10 PM
rubber roof over tar & thoughts on quote wfmrules3 Roofing/Siding 13 10-16-2011 09:00 PM
