Can I Put A Shower Pan On Tile - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-19-2013, 12:38 AM   #1
Rewards Points: 892
Can I put a shower pan on tile
I'm installing the following acrylic shower pan in my bathroom and have a question about tiling the floor. I was going to lay the pan on the sub floor and then tile around it but I got to thinking and didn't know how to butt the tile to the pan.
If you look at the picture, the base of the shower pan is angled and ornate. It doesn't look like the tile is meant to be butted up against it.
Could I lay tile in my entire bathroom, including the area of where the shower base is going and place the shower pan on the tile? it would make a cleaner look.
thoughts?
Daugela is offline   Reply With Quote
Old 06-19-2013, 05:30 AM   #2
DIY staff
Rewards Points: 7,174
I doubt if you will be pleased with the end result if you set the pan on top of the tile.
Here's why---
The pan needs mortar under it for leveling and reinforcement---this sometimes results in the pan lip not flush to the finished floor--the backer board and tile will hide that.
Pans sometime flex a bit---having the pan behind the backer and tile hides that and also help pin the pan to the floor.
your tiling might not be perfectly flat--leaving a gap--
Retrofit ceramic tile corner shelf in shower jgibbs Tiling, ceramics, marble 4 06-07-2012 11:29 AM
Shower tile specifics re: hair coloring Pammylu Tiling, ceramics, marble 4 06-05-2009 02:32 PM
Another newbie building a tile shower ChadC Building & Construction 7 08-25-2008 02:58 PM
Problem Glass Tile Shower robin2107 Remodeling 9 04-23-2007 08:19 PM
Shower tile need some help here dirtyb115 Remodeling 2 12-23-2006 12:27 PM
