Can I Put A Shower Door On A Fiberglass Tub/shower Combo? - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-07-2009, 09:13 PM   #1
They're all fixer-uppers
J187's Avatar
Rewards Points: 516
Can I put a shower door on a fiberglass tub/shower combo?
I have a tub/shower fiberglass unit by lasco - I am wondering if I will be able to put a tub door on it instead of the curtain... the thing is, the corners where tub and shower wall meet are a little rounded and there is a seam where the shower wall attaches to the tubwall.
J187 is offline   Reply With Quote
Old 03-08-2009, 12:40 AM   #2
Registered User
Termite's Avatar
You could install a sliding door that hangs from a track, but a hinged glass door isn't an option on a fiberglass tub enclosure. The fiberglass unit isn't strong enough to support the kind of weight that is involved in a hinged glass door.
Old 03-08-2009, 08:57 PM   #3
Rewards Points: 5,336
The rounded corners will be an issue as the vertical and horizontal pieces need to be sealed against the surface to prevent leaks. You might be looking into a custom frame that will match your profile.
Ron
Old 03-08-2009, 10:18 PM   #4
Tom Struble's Avatar
Rewards Points: 2,002
possibly the manufacturer has a door that fits your model correctly
Tom Struble is offline   Reply With Quote
Fiberglass Shower Base Install Q's yohan Plumbing 8 01-07-2011 03:46 PM
Backerboard under Fiberglass Shower Pan? BillyDIY Plumbing 2 12-17-2008 01:47 PM
Shower door install in unplumb fiberglass surround screenporch21 Building & Construction 1 11-24-2008 02:36 PM
Replacing a fiberglass shower Proulx06 Remodeling 11 06-20-2008 04:50 PM
