-   -   Can I install 12x12 porcelain tile on a shower wall or ceiling? (http://www.diychatroom.com/f15/can-i-install-12x12-porcelain-tile-shower-wall-ceiling-3973/)
dezigner80 09-18-2006 09:55 PM
I am remodeling my bathroom and want to install the same 12x12 porcelain tile on my shower wall and ceiling as I am installing on the floor. The guy at the "big-box" store said I couldn't install a 12x12 on the wall or ceiling. He said it would be too heavy.
I have seen 12x12 installed on walls before. Is it a good idea? What about the ceiling? If I can do it, do I need an additive to the thinset to make it adhere better?
FYI (if it matters): I'm using 1/2" GP Denshield backerboard.
Big Dave 09-18-2006 10:30 PM
I've seen it on the wall before but never ceiling. When you install it on the walls you will need to stick little nails under each end of each one to support it till the thinset dries. I would advise smaller for ceiling. If you go with the big you will need to support them till the thinset dries.
Dave.
joasis 09-19-2006 07:33 AM
I agree with Dave, except, we use the spacers to when setting on the wall, and generally, the mastic will hold them up...but take your time. I don't know if I would try to tile a ceiling....what if the tile came loose and cracked you on the head during a steamy shower? Or worse, a romantic steamy shower?
dougrus 09-19-2006 07:53 AM
12x12 is too big for a ceiling.
For the walls, use a GOOD non-sag thinset mortar. Backbutter to increase "suction" getting them up.
J187 09-19-2006 05:32 PM
My tile place has a gorgeous bathroom with 14" wall tiles diagnolly installed. It looks fantastic. Please don't take this the wrong way, but why would you want tiles on your ceiling? Personally I wouldn't want the hassle or risk. But if you do it, do like Dave said and go smaller up there.
gmcelum 09-13-2009 09:03 PM
For the walls, use a GOOD non-sag thinset mortar. Backbutter to increase "suction" getting them up. __________________
Doug Russell
I'm doing almost the same thing but I'm using standard size tiles that I'm cutting from floor tile scraps that my stepson has. I'm just curious, what do you mean by "backbutter" when applying the mortar?
Mickey53 09-15-2009 01:05 PM
Put thinset on the back of each tile before you stick it to the wall. Layer of thinset on the wall, layer of thinset on the tile.
