Can I Hang Suspended Ceiling At 2 Levels In One Room? - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-17-2013, 06:05 PM   #1
Can I hang suspended ceiling at 2 levels in one room?
Hi all- I'm about ready to sheetrock three rooms in my big basement project, and shortly after that, it'll be on to hanging the drop ceiling.
One of the rooms has an area (due to major bathroom PVC drain pipes above) that will have to be hung at least 5 inches level below the joists - if not closer to *7* inches down. But I'd really like to keep the 2/3 of the room's ceiling that *isn't limited by this pipe area, higher -- like 2 or 3 inches off the joists.
Is there a way to 'terrace' or set two levels of ceiling, and then join them with a vertical suspended ceiling tile cut, so that the whole room doesn't have to hang so low? I think I've seen this done before, but can a 1st time DIY'er like me do it?
I'll be using standard Armstrong hardware from Lowe's. Thanks,
Mike
mike dub is offline   Reply With Quote
Old 03-17-2013, 06:19 PM   #2
Framing Contractor
Rewards Points: 126
Yes it can be done.
sixeightten is offline   Reply With Quote
Old 03-17-2013, 06:42 PM   #3
thanks SixEighteen
Originally Posted by sixeightten View Post
Yes it can be done.
Do you know if Armstrong sells 90 degree rails/moldings that allow smooth 'vertical' paneling / closing of the gap between the two heights? Pretty easy to do?
Old 03-17-2013, 08:00 PM   #4
Rewards Points: 6,652
They make rails that you can secure Drywall against, but as for placing the drop ceiling panels as a wall, seen it done, and after a while it really looks shoddy, when the panels start drying out over time.
Old 03-17-2013, 08:38 PM   #5
Framing Contractor
Rewards Points: 126
Best bet there is to build a small framed bulkhead and drywall it.
The Following User Says Thank You to sixeightten For This Useful Post:
drtbk4ever (03-21-2013)
Old 03-18-2013, 07:09 AM   #6
All makes good sense. Small bulkhead drywalled sounds like the way to go. Thanks gregzoll and sixeightten
Mike
Old 03-18-2013, 07:33 AM   #7
Build it out of steel framing, not wood, since it will be more light weight, and still hold up like wood, but does not shrink like wood framing members do over time.
5000k Light Blulbs for Ceiling Fan Fixture (clean white light for living room) cmf0106 Electrical 10 01-12-2012 10:04 PM
Vaulted ceiling crown molding with adjacent room cmcfalls2 Carpentry 4 10-13-2011 10:38 AM
how to build toy shelf near ceiling of kids room Kimmoski Carpentry 2 06-22-2011 07:22 AM
Need Ceiling Idea for Ductwork that cuts Across Middle of Room skylake Building & Construction 8 10-19-2009 06:15 AM
Builder skipped ceiling joists in bonus room need advice minicus Carpentry 31 08-11-2008 10:44 PM
