Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 09-14-2012, 10:10 AM   #1
Can I get Custom 6 Panel Doors At Odd Sizes?
I am finishing my split level attic and looking for custom doors for the smaller closets. The three main doors in the room are normal size (rough opening 30x81, 32x81, 32x81). I would like the three main doors to be solid core 6 panel and the closet doors to be 6 panel either solid or hollow. My sub contractor wants to use plan wood doors for the closets but I think they all have to match. Can I even custom order 6 panel doors at 26x77, 27x60 and 25x57? I called home depot but the smallest they could do was 70 high. By the way for the large doors I need the frame but for the closet doors I just need the actual doors. Thanks for your help.
heyjoe91 is offline   Reply With Quote
Old 09-14-2012, 10:34 AM   #2
Why the odd ball sizes? Sure would be cheaper to just reframe the wall so standard doors would fit.
Old 09-14-2012, 10:36 AM   #3
The roof slops in those areas so a larger door is not possible. I tried to get as much closet space as possible. I've seen really mini 6 panel doors at people's houses in the past but not sure where to get them.
Old 09-14-2012, 11:06 AM   #4
joed's Avatar
If you go to a custom door manufacturer you should be able to get any size. The big box stores will not have the odd sizes.
Don't where you are located but this came up with google search. They build normal and custom sizes.
http://www.amberwooddoors.com/int-doors.html
Do not PM with questions that can be asked in a forum. I will not respond.
Old 09-14-2012, 11:11 AM   #5
I'm not sure why home depot can't order them. I ordered my custom doors through them but they were 80" tall I believe. Maybe they gave you sizes they have in stock?
Dwillems is offline   Reply With Quote
Old 09-14-2012, 05:54 PM   #6
paper hanger and painter
chrisn's Avatar
Definition of custom
1. Made to order.
2. Specializing in the making or selling of made-to-order goods:
Tips on painting 6 panel hollow core doors speedster1 Painting 28 06-19-2012 01:51 PM
Saw blade for hollow core 6 panel doors bryanp22 Windows and Doors 4 02-05-2012 11:54 PM
34" Wide Storm Doors Custom Size Only? kc27 Building & Construction 3 12-08-2010 01:34 PM
Passing wire to another panel theatretch85 Electrical 5 09-21-2009 12:09 AM
flat doors to 6 panel? Yeti Remodeling 8 03-05-2008 01:18 PM
