-   -   Can I get Custom 6 Panel Doors At Odd Sizes? (http://www.diychatroom.com/f15/can-i-get-custom-6-panel-doors-odd-sizes-156780/)
heyjoe91 09-14-2012 09:10 AM
I am finishing my split level attic and looking for custom doors for the smaller closets. The three main doors in the room are normal size (rough opening 30x81, 32x81, 32x81). I would like the three main doors to be solid core 6 panel and the closet doors to be 6 panel either solid or hollow. My sub contractor wants to use plan wood doors for the closets but I think they all have to match. Can I even custom order 6 panel doors at 26x77, 27x60 and 25x57? I called home depot but the smallest they could do was 70 high. By the way for the large doors I need the frame but for the closet doors I just need the actual doors. Thanks for your help.
joecaption 09-14-2012 09:34 AM
Why the odd ball sizes? Sure would be cheaper to just reframe the wall so standard doors would fit.
heyjoe91 09-14-2012 09:36 AM
The roof slops in those areas so a larger door is not possible. I tried to get as much closet space as possible. I've seen really mini 6 panel doors at people's houses in the past but not sure where to get them.
joed 09-14-2012 10:06 AM
If you go to a custom door manufacturer you should be able to get any size. The big box stores will not have the odd sizes.
Don't where you are located but this came up with google search. They build normal and custom sizes.
http://www.amberwooddoors.com/int-doors.html
Dwillems 09-14-2012 10:11 AM
I'm not sure why home depot can't order them. I ordered my custom doors through them but they were 80" tall I believe. Maybe they gave you sizes they have in stock?
chrisn 09-14-2012 04:54 PM
Definition of custom
1. Made to order.
2. Specializing in the making or selling of made-to-order goods:
