Can I Fix This Countertop? *Pics* - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-28-2008, 10:16 AM   #1
Can I Fix this Countertop? *Pics*
I was wondering if I can fix this with some type of glue. This is the kitchen counter with some type of laminate glued on it instead of granite.
I was wondering if there is some type of commercial strength glue I can use to glue the laminate back down or if I will have to replace it. I took pics with the flash on and off. It's a total of about 4 feet long (the lifting).
girlscandoittoo is offline   Reply With Quote
Old 05-28-2008, 10:41 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Hard to tell with your pics, but, I use a hot glue gun to fix separating laminate....
- Build Well -
Old 05-28-2008, 12:11 PM   #3
^^Sorry about the pics. I had to make them smaller in order to attach them.
Old 05-28-2008, 09:12 PM   #4
Remodeler
MinConst's Avatar
Is that a small strip in on the back or the counter? You might add a back splash of a contrasting laminate to cover the loose piece. Tiling the backslash would do the same. Re-gluing it will last for awhile but not long. I would use contact cement carefully to re glue it.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Cutting existing formica countertop the mailman Carpentry 11 05-02-2008 11:24 AM
Plywood under quartz countertop? kbrinton Remodeling 5 04-11-2008 07:04 PM
Countertop (Formica) mess and husband's ego - HELP! frustratedwife Carpentry 3 11-12-2007 10:10 PM
Sanding Cultured Marble Countertop? a2116 Remodeling 2 05-31-2007 04:39 AM
Countertop sink hole Grebus Remodeling 1 08-31-2005 10:09 PM
