Can I Fix This? - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-12-2014, 09:38 PM   #1
Can I fix this?
I was vacuuming out my vent in the bathroom and when I was done I found that my vacuum ruined my cabinet. It looks like the cabinet is plastic - ish and melted from the hot air, blowing from the vacuum.
P.s. I am not a fixer upper so please simplify!
mavindrummer is offline   Reply With Quote
Old 04-12-2014, 10:09 PM   #2
Rob
Robpo's Avatar
Rewards Points: 826
If it melted from the vacuum it can't cost too much to replace and would be easier than trying to fix the old one if that is what you meant.
Robpo is offline   Reply With Quote
Old 04-12-2014, 10:30 PM   #3
Rewards Points: 402
The door is a thermofoil film over an mdf door. The door is coated with a heat activated adhesive, the hot film is laid over the top, then a vacuum pulled from underneath. The hot air from the vacuum reactivated the adhesive and misshaped the film. The only way to really fix it is to put it under a vacuum again. You might be able to find a similar door style and film pattern. Do a search for cabinet door refacing and see if you can find something.
taylorjm is offline   Reply With Quote
The Following 3 Users Say Thank You to taylorjm For This Useful Post:
mavindrummer (04-12-2014), SHR Plumber (04-22-2014)
Old 04-13-2014, 05:08 AM   #4
Rewards Points: 4,538
in simple terms, no, you cannot,,, you already said you're not a ' fixer-upper '
The Following User Says Thank You to stadry For This Useful Post:
mavindrummer (04-13-2014)
Old 04-13-2014, 10:26 AM   #5
Lol! ! Thanks... I would like to learn how though. If possible. I fixed my dishwasher and my toilet by watching YouTube videos. Now I need to fix my fridge and this darn cabinet
Sent from my SGH-M919 using Tapatalk
Old 04-13-2014, 03:19 PM   #6
good for you ! never had youTube when i grew up on a farm
Old 04-13-2014, 03:26 PM   #7
Rewards Points: 402
Me too, but unfortunately, this isn't something that can be fixed. I used to have a vacuum former and used it to cover thermofoil doors, and if you screw up, you throw it away.
Here is a site that I've used in the past. They have several types of doors you can order with whatever profiles you want. You can also order a sample of the white thermofoil and see if it would match your current color.
http://www.refacedepot.com/
If I had to guess I think your door profile is a N501 under the thermofoil door section. They have about 3 different color of whites so I would probably ask for a sample.
Old 04-22-2014, 09:01 PM   #8
videos
Try to watch on youtube videos. Lots of interesting videos.
jasper121 is offline   Reply With Quote
