Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 09-02-2007, 02:00 PM   #1
flu
can i cover bare wood with hotmudd
I had a contractor knock down a wall and put a header in. He finished it by mudding directly over the bare wood because the header he built was too wide to hang drywall over. The mudd did not adhear and cracked throughout. I have since cleaned it all up back to square one but don't know how to proceed. There is only about 1/8 in. room from the surface of the header to the outer surface of the surrounding drywall. The best i can figure is i need something thin enough to hang over the header to subsitute for drywall or some kind of precoat that would allow the finish coat to adhear to the bare wood. Would some kind of mesh work here?
flu is offline   Reply With Quote
Old 09-02-2007, 10:25 PM   #2
remodeling pro
Hope someone else has a magic solution for you, because I don't know of anything you can do that is going to keep the skim of mud from cracking due to the wood movement. Why didn't you get this clown to build the header correctly?
troubleseeker is offline   Reply With Quote
Old 09-02-2007, 11:32 PM   #3
They have 1/4 " drywall. You should be able to feather out the 1/8" projection.
What was the reason the header was made too large? And it wasn't because it was needed. I don't care what the contractor says.
Ron
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 04:29 PM
Repairing the wood for painting bofusmosby Painting 4 06-17-2007 12:55 AM
Permanent Wood Foundation Question opee Building & Construction 2 03-19-2007 10:27 AM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 10:14 AM
Wood to Concrete without Drilling MattStata Carpentry 1 04-19-2006 05:16 PM
