Can Drywallers Cut Into Existing Textured Ceiling? - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-05-2006, 02:42 PM   #1
Rewards Points: 129
Can drywallers cut into existing textured ceiling?
I'd like to try to keep the existing textured ceiling in a room I am remodeling, but I need to take a wall down and move it. So the new wall would go up to the old ceiling and it would need to be drywalled. Can they cut in that corner where it all meets pretty nicely?
wease is offline   Reply With Quote
Old 12-05-2006, 07:17 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
If you are saying that you would like the new wall finished off right up to the existing ceiling without effecting the ceiling texture....Then:
Yes, it can be done... if they are experienced tapers.
We have down exactly what you are describing....many times.
Good Luck
- Build Well -
Old 12-23-2006, 12:40 PM   #3
Send a message via Yahoo to Joe61
Textering is very technical work. There are a viarity of guns shooting gaps which you would need to consider to match the existing one. I sudgest:
1- You have a few cartboard samples at various gun gaps and try the better match.
2- Try to mix the mud at a perfect yougart texture on all samples.
Hope these tips help.
Joe61 is offline   Reply With Quote
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
how do I remove textured paint without taking whole ceiling down johnsuchow Painting 5 09-09-2008 09:42 PM
Mating sheetrock to textured ceiling atlfiveo Building & Construction 2 02-05-2007 10:43 PM
Textured Ceiling jerome8283 Painting 6 08-21-2006 11:10 AM
Painting textured ceiling Unregistered Painting 5 06-17-2005 01:27 PM
