Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 07-31-2009, 08:47 AM   #1
Can this door sweep be used vertically?
Can this door sweep be used vertically? (so it can slide with the door)
I was thinking of getting 3 of them, and placing them vertically on my patio door.
Good idea or no?
http://www.amazon.com/M-D-Building-P...9043903&sr=8-1
TIA
abefroman is offline   Reply With Quote
Old 08-01-2009, 07:05 AM   #2
You probably could, but why??? There are products made for the verticle jambs and they fit in length.
Old 08-06-2009, 01:36 PM   #3
Renovation Contractor
Paragon's Avatar
Bad idea.
Call a reputable handyman, window and door contractor (as there may be other issues going on that need to be addressed, visit a reputable window and door store to get their advice or visit with your local big box store for their advice.
That application is a vinyl strip that is intended as a door sweep and is not meant for use as a gasket/ seal. Even if you were looking for a sweep I wouldn't recommend using it and now my next question is why were you going to purchase it off amazon without seeing what you were buying or were you just using it for visual representation?
Good luck and be safe
James D. Van Raden
Owner, Paragon Renovations Moorhead, MN/ Fargo, ND
"Committed to providing the finest renovation services available"
Paragon is offline   Reply With Quote
Dyrwall for Mobile Home Suncrest79 Building & Construction 3 03-04-2009 08:05 AM
Placing roof sheathing vertically Clutchcargo Building & Construction 5 08-26-2007 11:21 PM
