Can Door Jambs Be Repaired Or Just Get A New Door? - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-08-2010, 07:38 AM   #1
Can door jambs be repaired or just get a new door?
Was looking for some advice on my exterior door. Wind caught the storm door and ripped the door jamb apart at the top and bottom. Can the door jamb be repaired cheaper then a new door?
I am leaning towards a new door that I'll get an energy tax credit on, that is only around 200.00.
Thanks,
Bryan
bkeech is offline   Reply With Quote
Old 10-08-2010, 08:03 AM   #2
Household Handyman
Rewards Points: 1,408
At least in my area: Door jambs can be purchased and replaced. This sounds as if it is the hinge side of the door frame which will be a little more work involving mortising in the door hinges. A decent DIY'er should be able to do this. I do these often for much the same reason, or if a door gets kicked in. Door jambs here run about $28 each. David
Old 10-08-2010, 11:32 AM   #3
Rewards Points: 590
If you do decide to replace the door, Lowes sells decent Larson doors under $200. I would recommend going up to the models between $200 and $250 so you can get a better handle (I have one with the brass hardware and privacy lock), but all of them qualify for the energy credit.
operagost is offline   Reply With Quote
Old 10-08-2010, 06:59 PM   #4
Rewards Points: 292
The section of the jamb that holds the hinge can be cut, removed and replaced for a lot cheaper that replacing the door. Remove your trim pieces, set a circular saw to the dept of the jamb and cut a few inches above and below the damaged area.
Jim F is online now   Reply With Quote
Old 10-08-2010, 07:42 PM   #5
How old is the door? Do you know if it was insulated around the jamb? Might be a good time to replace the whole door to upgrade. That is what I would do at least.
wnabcptrNH is offline   Reply With Quote
Old 10-08-2010, 10:09 PM   #6
Rewards Points: 5,336
When you put the new storm door in, install one of those chain restrictors at the top. It's cheap insurance.
Ron
Tags
door jamb
Adjusting Garage Door torsion springs INGunGuy Building & Construction 4 10-12-2009 07:22 AM
Rehanging an exterior basement door tputkey Building & Construction 9 05-21-2009 03:19 PM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 03:01 AM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 09:13 PM
