Can Anyone Identify This Tub/shower Door With A Screw Adjustable Friction Fit? - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-30-2010, 01:02 PM   #1
Chicago, IL
Michael Thomas's Avatar
Can anyone identify this tub/shower door with a screw adjustable friction fit?
I've not seen this before and need replacement parts: the upper and lower rails on the frame of this tub/shower assembly are screw adjustable to achieve a friction fit with the walls:
Can anyone identify the manufacturer?
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 01-31-2010, 10:35 AM   #2
Chicago, IL
OK, found it.
For the benefit of anyone else who finds this as a result of a search:
http://www.sterlingplumbing.com/onlinecatalog/pdf/1011075_2.pdf
Can't get set screw in TP holder loose janralix Plumbing 4 08-12-2009 10:47 PM
I need to identify this screw konsole General DIY Discussions 6 02-24-2009 08:49 AM
