Can Anybody Tell Me If This Is The Proper Way To Frame A Basement? - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-09-2007, 12:25 PM   #1
Question
Can anybody tell me if this is the proper way to frame a basement?
I poured foundation wall, we drylocked it , we are going to frame it with treated 2x4's with the tripple coated screws. We are going to put styrofoam insulation in.
As far as drywall should we use the greenback drywall or regular drywall. And should we use the tripple coated screws or standard to secure the drywall???
ktwags is offline   Reply With Quote
Old 05-09-2007, 01:55 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Since you are screwing into Pressure Treated lumber framing, you should use some kind of galvanized, stainless, or coated screws to avoid the screw reacting and corroding due to the treatment of the lumber.
Link: http://www.grip-rite.com/articles.asp?Action=5
The most cost efficient screw would be the gray coated screws at 1 1/4" length, found in the exterior treated screw section at any large HOME IMPROVEMENT store chain.
I would not bother with 'green board' (Moisture Resistant board).
It seems that you are highly concerned about moisture in your basement. So, you might want to consider 'XP board' or 'Densarmor'.
See the links below:
XP BOARD:
http://www.nationalgypsum.com/products/product69.aspx
http://www.nationalgypsum.com/litera...pwallboard.pdf
DENSARMOR:
http://www.gp.com/build/product.aspx...4659&hierarchy
- Build Well -
Old 05-09-2007, 03:22 PM   #3
Rewards Points: 790
If you are concerned about moisture...I would recommend waiting until you have some rain to see how damp the basement gets. Take a small piece of plastic (12"x12") and tape the edges down on the floor and/or wall. After a day or so or humid or rainy weather, check and see if there is moisture underneath the plastic. If there is, you have a damp basement and you may need to investigate and fix this problem before you begin your remodel. If not, then standard drywall should be okay.
cibula11 is offline   Reply With Quote
Framing a basement ledge nlexi912 Building & Construction 8 11-14-2011 04:24 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 09:09 AM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 09:55 PM
How to 'start' finishing the basement... mcvane Building & Construction 18 06-04-2007 08:28 AM
Basement Remodeling Help DMonkey6972 General DIY Discussions 5 01-15-2007 12:35 PM
