Bypass Doors - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-05-2010, 04:59 PM   #1
bypass doors
I want to have bypass doors in front of 2 closets that are side by side and had bifold doors in them. I took the doors off and hung curtains because this is my quilt studio and I need access to my fabric. I have the idea that I can hang bypass doors from the ceiling to cover the entire wall. I don't need heavy doors because I want to use the doors as my design wall. when closed. What is the easiest, cheapest way to do this?
sharonb is offline   Reply With Quote
Old 01-05-2010, 10:57 PM   #2
The problem would be hanging them from the ceiling. This would be possible (easiest) only if the ceiling joists were running the proper direction or in the ideal spot to hang a track from. Building a frame out of 2x2's and covering them with fabric would probably be the cheapest. Building the doors out of plywood would probably would be the easiest. If you choose to go the plywood route, heavy duty hardware would be the way to go.
Work is for those who can not fish.
Mop in Hand is offline   Reply With Quote
Input on which doors to replace interior & exterior door with... tomas21 Carpentry 13 12-08-2009 09:32 AM
Installing Bypass Shower Doors pianodude Building & Construction 2 09-08-2009 06:09 AM
Installing closet doors into un-true opening - Need ideas McCool Carpentry 8 08-12-2009 01:37 PM
Bypass Shower Doors Install Question houston Kitchen & Bath Remodeling 4 01-31-2009 07:55 PM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 05:04 PM
