Originally Posted by oh'mike
Remove the top trim---
Look for screws holding the top box to the wall---remove those--they should be spaced 16" apart--
Once the top section is removed--see if the counter top is removable---if it is remove that--
Remove trim at floor--unscrew cabinet from wall---should be screws on back of cabinet just under the counter top---
Well....I was going to suggest a BFH.....but I guess the above method is a bit 'cleaner'.
If I was making that cabinet....I would have either nailed the face frame on with finishing nails or used pocket screws.
Pocket screws will have an angled hole cut in the side of the wood. The screw uses a square head bit to remove.
