Building a shower pan
I am in the process of building a mud shower pan. I have looked at many sites and some show blocking in between the studs to staple the shower pan liner too and other sites have no blocking and staple directly to the studs.
Ok, so what is the correct or preferred method? And if it is the "block" method, what advantage does this provide?
Also, what is the procedure where the shower pan liner wraps the curb? How do you actually cut/fold/glue the liner to make this area where the horizontal curb meets the vertical wall waterproof?
Thanks!
Reason: add info
