Building Raised Attic Floor Question - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-26-2012, 12:07 PM   #1
Building raised attic floor question
Hey gang, first time poster here. Got what will likely be a simple question. I want to build a raised floor in my attic, such that the floor covers the exposed ducts. If I lay 2x6s on their side on top of the existing joists that would give the clearance necessary. Is that safe? Should I instead sister 2x10s next to the existing joists? Hopefully this makes sense. Thanks in advance - Dave
nocarters is offline   Reply With Quote
Old 03-26-2012, 12:12 PM   #2
Rewards Points: 13,712
What's there now for joist? Is it trusses or site build rafters?
Lot's of times an attic was not built for anymore then light storage and can cause damage to the ceiling below if this is not done right.
AndyGump (03-26-2012)
Old 03-26-2012, 01:27 PM   #3
Just a DIY guy
I have done this, and there were a lot of issues.
But as joe asked, you have to determine whether you have trusses (looks like a bunch of "W"s crisscrossing the attic space), or a "stick built" frame.
M3 Pete is offline   Reply With Quote
Old 03-26-2012, 04:24 PM   #4
Thanks guys. The house was built in 1986 (Apex, NC). I'm pretty sure it's or a "stick built" frame - I'll confirm the size of the joists tonight. I'd curious what the issues you had were. Thanks again.
Old 03-27-2012, 08:07 AM   #5
Help with raised attic floor
It's site built, not trusses. I guess the question is do I lay the new joists parallel or perpendicular to the existing 2x10 joists?
Old 03-27-2012, 09:23 AM   #6
Just a DIY guy
What is the joist spacing? How long is their unsupported run?
If you have 2x10, why do you need additional height for floor?
10 inches of fiberglass is r30
Old 03-27-2012, 11:07 AM   #7
I want to raise the floor to cover exposed duct work in the attic - currently this lies on top of the existing joists...
Old 03-27-2012, 02:25 PM   #8
Just a DIY guy
is the duct work parallel or perpendicular to the joists? Or both?
a 2x6 is 5.5 inches tall (wide), will that clear the ductwork?
If you can lay plywood on the existing 2x10's, you might be able to build some 3-sided plywood boxes to cover the ducts. Depends on how many ducts and how they are spaced.
A 2x10 is a substantial ceiling joist, but we still need to know the spacing and how long the unsupported runs are.
Old 03-27-2012, 03:01 PM   #9
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
What is the purpose for covering the duct work?
Are you planning to use the floor space as living area or storage?
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
The Following User Says Thank You to AndyGump For This Useful Post:
M3 Pete (03-27-2012)
Old 03-27-2012, 03:34 PM   #10
Raised attic
Thanks for all the replies. The raised floor would be used just for storage - mostly lightweight (no old barbell sets etc...). From time to time I'd walk on it just to add or remove items. I'll try to answer the other queries tonight from home. Thanks again all!
building raised subfloor for shower chulett Building & Construction 12 02-02-2011 07:36 PM
Ventilating attic with two roofs senorbungle Building & Construction 2 01-09-2011 04:17 PM
Attic fan options. P550 Electrical 6 08-22-2010 12:30 PM
Excess moisture/condensation/frost in attic Fingers General DIY Discussions 2 12-29-2009 10:38 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
