Building A Garage - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-24-2012, 12:20 AM   #1
Building a garage
i have an asphalt foundation and would like to know how to begin with the framing? mainly how to keep the water out.
thaynes is offline   Reply With Quote
Old 02-24-2012, 01:19 AM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 674
Send a message via Skype™ to AndyGump
Asphalt would be a very unusual foundation material.
Do you mean that you have an asphalt pad and you want to start building a garage on that?
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 02-24-2012, 06:14 AM   #3
A garage requires the same foundation that your house is built on. One that starts below the local frost line. Building on a slab without a proper foundation is bad practice. The building would not survive for long.
Old 02-24-2012, 06:17 AM   #4
Framing Contractor
There is no such thing as an asphalt foundation. If you think you can build on your driveway....you can't. You NEED a foundation.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 02-24-2012, 06:18 AM   #5
Stay-at-home GC
Big project. You better take the Elephant Eating approach.
1. Pics of the site
2. Plans for what you want
3. Township/ Municipality Reqs
4. Budget & Time Frame
5. Available resources (tools, labor, skill set)
I'll think of some more as soon as the coffee kicks in.
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 02-24-2012, 06:19 AM   #6
Stay-at-home GC
6. Survey of lot with set-backs, easements, ROW etc.
Come on coffee, come on...
Old 02-24-2012, 06:22 AM   #7
Stay-at-home GC
Will you be handling the whole thing or subbing some out?
Which parts will you sub?
Are you required to sub the Electric to a Licensed Electrician(not uncommon).
Old 02-24-2012, 06:24 AM   #8
Stay-at-home GC
You can, you'll just have to tear it down in a few years
Old 02-24-2012, 06:28 AM   #9
Stay-at-home GC
8. A Schedule (Cup number 2?). While not essential, a Gantt chart showing Critical Path with dependencies and time estimates for each step will help make sure that your Electrician arrives on or around a day after your Framing is completed but before you Insulate.
Old 02-24-2012, 06:32 AM   #10
Stay-at-home GC
All of the steps above have an order that makes more sense than I listed them. For example, you should not go out and pay for a Survey until you have done a design and budget.
Least expensive and permanent to most expensive and permanent is a good rule of thumb.
You'll waste less time and resources by handling "Proof of Concept" issues up front.
Ask "Can this project be completed realistically?" before you ask "How do I complete this Project?"
Old 02-24-2012, 06:42 AM   #11
Stay-at-home GC
9. A Rough Take-off (Materials and Labor Estimate) followed by revisiting the Budget, followed by a Detailed Take-off.
10. Working Drawings not just a Concept. Build it on paper at least three times (its lighter)
Sketch-Up is a great tool for this.
Old 02-24-2012, 06:45 AM   #12
Stay-at-home GC
Here endeth the coffee fueled monologue
The Following User Says Thank You to CplDevilDog For This Useful Post:
AndyGump (02-24-2012)
The 12-Gauge Garage Jack Olsen Project Showcase 28 07-08-2012 10:21 PM
Building Garage overhead Storage swenard Building & Construction 15 01-23-2012 02:01 PM
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 10:32 PM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Close to building my garage. Need help on framing a roll up door, some other things. J S Machine Building & Construction 0 01-06-2011 06:50 AM
