Broken Shower Drain Bolts - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-21-2013, 08:35 PM   #1
Broken shower drain bolts
Hello. I'm in the process of remodeling my bathroom. Currently I have the shower demolished. While in the process of taking out the old, vinyl shower pan, the bolt heads on 3 out of the 4 flange bolts going into the shower drain broke off. These are siezed, stainless steel 1/4 inch bolts. I've tried without success to remove these bolts using the 'Grabit Pro' bits. Can anyone provide some pointers on how I may be able to get these bolts extracted? I'm afraid I may end up having to cut out the concrete and replace the actual drain.
Your input is greatly appreciated!
Chad
crisch is offline   Reply With Quote
Old 02-21-2013, 08:40 PM   #2
Rewards Points: 13,732
What are you replace the old pan with? If your going to try and tile it you would have to change it anyway.
Old 02-21-2013, 08:53 PM   #3
MarginallyQualified
Rewards Points: 2,464
Hilti makes a nice sds hammer drill
Old 02-21-2013, 09:02 PM   #4
At the drain, the vinyl was sandwiched between the drain base and the drain flange. I had to take off the drain flange to get the vinyl out. My hope was to leave the drain base in place, install a new pvc pan, put the drain flange and drain barrel back in place, spread a new mortar bed and then tile over the mortar bed.
My issue is getting the broken bolts out of the drain base.
Old 02-22-2013, 05:02 AM   #5
DIY staff
Rewards Points: 7,174
I think you will end up opening up the concrete----I believe you will dislodge the metal threaded inserts when you drill out the the broken screw----I know you did not have this in your plans---but it happened---I would not trust an old clamping flange----failure will mean re doing the entire job---big risk to save a $35 part.
floor drain to shower drain? The Dogger Plumbing 4 01-30-2013 09:02 PM
Quick question: shower drain gaskets MANGINA Plumbing 8 09-08-2012 07:32 PM
old two handled shower broken. Mary Thorman Plumbing 0 10-05-2011 07:05 PM
New tiled shower won't drain; mortar in drain. catitudes Plumbing 5 03-29-2009 01:08 PM
First shower install, drain help please! tigerbalm2424 Plumbing 6 01-16-2008 05:44 AM
