-   -   Broken shower drain bolts (http://www.diychatroom.com/f15/broken-shower-drain-bolts-172618/)
crisch 02-21-2013 08:35 PM
Hello. I'm in the process of remodeling my bathroom. Currently I have the shower demolished. While in the process of taking out the old, vinyl shower pan, the bolt heads on 3 out of the 4 flange bolts going into the shower drain broke off. These are siezed, stainless steel 1/4 inch bolts. I've tried without success to remove these bolts using the 'Grabit Pro' bits. Can anyone provide some pointers on how I may be able to get these bolts extracted? I'm afraid I may end up having to cut out the concrete and replace the actual drain.
Your input is greatly appreciated!
Chad
joecaption 02-21-2013 08:40 PM
What are you replace the old pan with? If your going to try and tile it you would have to change it anyway.
TarheelTerp 02-21-2013 08:53 PM
Hilti makes a nice sds hammer drill
crisch 02-21-2013 09:02 PM
At the drain, the vinyl was sandwiched between the drain base and the drain flange. I had to take off the drain flange to get the vinyl out. My hope was to leave the drain base in place, install a new pvc pan, put the drain flange and drain barrel back in place, spread a new mortar bed and then tile over the mortar bed.
My issue is getting the broken bolts out of the drain base.
oh'mike 02-22-2013 05:02 AM
I think you will end up opening up the concrete----I believe you will dislodge the metal threaded inserts when you drill out the the broken screw----I know you did not have this in your plans---but it happened---I would not trust an old clamping flange----failure will mean re doing the entire job---big risk to save a $35 part.
