Broken Drill Bit . . . - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-21-2008, 12:05 AM   #1
While trying to drill some small holes in my aluminum exterior windows to put some security pins in (we've had some burglaries recently), the drill bit broke inside the window and now I can neither remove the embedded bit or open the window. Anybody had a similar issue and had any luck removing the bit?
chins01 is offline   Reply With Quote
Old 01-21-2008, 12:25 AM   #2
Rewards Points: 150
small needle nose pliers
If that is too big try a couple wire coat hangers straightened to get on both sides of it to wiggle and remove with the slots of the bit.
makes ya wonder why we dont do things MORE carefully the first time. Or drill a bit larger hole now.
How big is the hole and how deep is it to the edge of the bit??? Can you take the widow apart at all to get closer to it??
justdon is offline   Reply With Quote
Old 01-21-2008, 02:18 AM   #3
Woodworker and Contractor
Kingfisher's Avatar
Rewards Points: 150
Move to the next, that one sounds secured, LOL how much broke off? If you can't get to it with the plier could you use a punch add drive the bit into the second sash fully so its not pinning both of them and just leave it there?
Kingfisher is offline   Reply With Quote
Old 01-22-2008, 01:39 PM   #4
Rewards Points: 5,336
There's a tiny hole saw(1/4") bit made for this situation. It drills around the broken bit or screw and releases it. I think I bought one from Rockler a few years back. Try their website.
Ron
Old 01-24-2008, 11:38 PM   #5
Thanks for all the help guys! All good suggestions. I'm going to try the Rockler part first and then use the other suggestions as necessary.
Thanks for the time to post and I'll see what works!
Best,
recommendations for an all-purpose drill mcvane Tools 18 11-29-2007 09:12 AM
Best cordless hammer drill for occasional use jaym3 Tools 6 11-11-2007 07:26 PM
Broken Drill Bit Freelancer General DIY Discussions 15 03-29-2007 04:01 PM
