Broken Door Jamb - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-08-2006, 09:04 PM   #1
broken door jamb
I have a broken door jamb and I need an inexpensive fix for it....I am thinking that liquid wood/wood epoxy is my best bet but I don't have much experiance with these products at all. How does liquid wood/ wood epoxy hold up to having screws placed in it after it has dried? Are there any other ways to fix this problem without completly replacing the door jamb? Here is a picture of the jamb...
tanneyman13 is offline   Reply With Quote
Old 05-09-2006, 08:54 AM   #2
Oldguy
Rehabber's Avatar
Cut out the broken section so that a 1x2 will fit in. Glue & screw to the original jamb. Then use Bondo (body putty) to smooth out any imperfections, Sand and refinish.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
broken lug studs LanterDan Automotive Repairs 19 02-01-2009 08:13 PM
Broken floor flange for toilet billy Plumbing 10 03-13-2008 07:58 PM
Broken Drill Bit Freelancer General DIY Discussions 15 03-29-2007 04:01 PM
Broken Brake Shoe powrus Automotive Repairs 11 01-16-2007 05:40 PM
Broken garage joists RBoncelet Carpentry 5 11-05-2006 12:55 AM
