Brick Wall Fireplace Questions
Hi, so you want to cover the brick is that right? If you do the stud wall, the fire place might become to recessed. An option is installing strapping on the brick, then drywall or cement board overtop. The thickness of strapping should be good enough for hdmi, speaker and power cables. You can always notch out the brick if you need more room for your cables. With proper anchors, you can safely mount your tv to the brick or in the mortar.
Removed link to company website
Reason: Removed link to company website
