Breaking A Cast Iron Tub? - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-07-2012, 12:19 AM   #1
Rewards Points: 682
breaking a cast iron tub?
I was surprised to find out an old problem bathroom of ours has a cast iron tub!
I really don't want to touch it. But if someday I have to, I read you can break it up with a sledge hammer. If we have to really whack it, is it possible the studs around/under it could be damaged? It would be TERRIBLE to drag that thing down some narrow stairs.
darsunt is offline   Reply With Quote
Old 02-07-2012, 12:30 AM   #2
Rewards Points: 13,450
The tub weighs about 400 lb. and was most likly installed before the walls were in place.
It's not attached to the studs, the weight holds it in place.
A few wacks in the middle toward the bottom and just keep hitting it to break in half.
It's not going to hurt the studs. Even if it did you talking about a $3.00 item to replace.
Old 02-07-2012, 06:21 AM   #3
DIY staff
Rewards Points: 7,174
They crack easily enough----Firm thumps--not brutal blows---just keep thumping the same spot with a sledge--a crack will start--then 'chase' the crack with your hammer and the crack will grow--
Goggles and gloves--that thing is covered with glass---
I usually start on the inside -front---easiest place for me---About 30 minutes--start to finish---
plummen (02-12-2012)
Old 02-07-2012, 06:37 AM   #4
Hammer away from the surrounding walls. The tub is not anchored to the walls but is against them. Beating the iron toward the wall can move the wall, words of experience. As suggested, start at the outside inner wall first. Once it starts to crack, it get easyier.
The Following User Says Thank You to Just Bill For This Useful Post:
oh'mike (02-07-2012)
Old 02-07-2012, 03:58 PM   #5
Rewards Points: 27
I'm redoing a bathroom. Have a thread a little lower that I will be updating shortly. Anyway only thing left to demolish is 300-400 pound cast iron tub. You guys already answered the question of hitting it and maybe pushing the studs. It seems like that is no big deal.
Other question is how is the drain of the tub attached to the waste pipe. I unscrewed the overflow valve and a chain connected to a cylinder came out. The drain only has a screw to remove the screen. I don't want to start banging this thing if its is screwed to the drain pipe. Last thing I need to do is damage the pipes.
jasesun23 is offline   Reply With Quote
Old 02-07-2012, 05:21 PM   #6
Rewards Points: 81
Would scoring or perforating with cut off wheel help any? I have been think about replacing mine and that was an idea I had. I'm thinking like a dremel or something.
Total Tool is offline   Reply With Quote
Old 02-07-2012, 08:33 PM   #7
Rewards Points: 582
we throw a old drop cloth over the tub while breaking it ..keeps glass from flying around
Old 02-07-2012, 08:41 PM   #8
http://www.superiortool.com/tools/sp...tool/06020.htm
Ridged makes a better one. Any lowes or HD will have them.
Waste of time using a dremal tool. By the time you got it set up and pluged in I could have it 1/2 way out.
Old 02-07-2012, 10:04 PM   #9
Rewards Points: 81
Oh, I meant the tub in general, not the drain. Would it be worth any effort to score some spaces on the tub? My tub is surrounded on three sides and I would want to keep drywall repair to a minimum.
Old 02-08-2012, 05:31 AM   #10
DIY staff
You will want to remove the chrome drain in the bottom of the tub--or unhook the drain set from under the tub.
You will need to remove some drywall in order to slide in the new tub---
Old 02-08-2012, 01:22 PM   #11
Rewards Points: 27
Got the drain tool from home depot for less then 10 bucks. Drain came right out. Took the sledge hammer to it and broke it up in about 30 mins. Could only really take half swings but a couple hits to the same spot and it just started cracking. The porcelain shards shoot every where so used a towel to cover as well as gloves, eye protection and ear protection just like everyone said.
Included some pictures for dramatic effect. Man clean up is the worst part.
Thanks for the help guys.
Jay
breaking a cast iron tub?-img_0737.jpg   breaking a cast iron tub?-img_0736.jpg   breaking a cast iron tub?-img_0738.jpg   breaking a cast iron tub?-img_0740.jpg
Old 02-10-2012, 08:20 PM   #12
DIY staff
Nice pictures---Thanks for the update!
Old 02-11-2012, 10:07 PM   #13
Sell it
Easiest way to get it out is to sell it on Craigslist, preferably before demolition starts. I got 2 old tubs out without lifting a finger.
My brother installed a new cast iron tub like this one by himself. Dragged it up the stairs with a rope.
JumpinJW is offline   Reply With Quote
Old 02-11-2012, 11:27 PM   #14
Rewards Points: 682
Were they ancient tubs? How much did you sell them for? And did you have to keep an eye on the buyers to make sure they did not destroy your bathroom in the process?
Old 02-12-2012, 06:18 AM   #15
DIY staff
That old iron is worth money at any scrap yard---if its not worth your time to scrap it--that will vanish off the curb in short order--a scrapper will pick that up for you--
pvc to cast iron hub using fernco-can't get it! What have I done Plumbing 10 01-22-2014 07:55 PM
Bathtub Recommendations - Cast Iron or other? HandyFrank Plumbing 5 10-25-2011 03:25 PM
Help me! Cast Iron Leak (Picture) meandiet Plumbing 8 08-14-2011 04:41 PM
cast iron or pvc treerat Plumbing 1 03-29-2011 06:38 AM
working with cast iron ericadami Plumbing 9 11-30-2008 12:45 PM
