-   -   board and batten siding (http://www.diychatroom.com/f15/board-batten-siding-64315/)
david1031 02-13-2010 12:45 AM
im ready to put new board and batten siding on my house - I'm not sure where I'm supposed to by the wood from though - a local saw mill? I know I want to stain it a certain color and I know how to install it just need to know where is the most common place to buy it.
Just Bill 02-13-2010 07:11 AM
I assume you are talking about rough sawn cedar or similar?? Any good lumberyard can supply you, but not big box.
oh'mike 02-13-2010 07:29 AM
Local woods--
David I don't know what local woods you have--I suggest that you check in at this saw mill forum and ask what local wood will make for a long lasting siding.
Buying from a local wood mill can save you some serious money.
And at the same time you're helping a local cutter feed his family:thumbup:
You just need to find out if there are local woods appropriate for your needs.
The Forestry Forum - Index ----Have fun---Mike---
here is a link to a cutter that has a good list of small mills across the nation. Google saw mills Kentucky-see what turns up.
Nelsonwoodworks.biz - Home
bjbatlanta 02-13-2010 10:22 AM
Rough sawn cedar or cypress are the norm. Pine could be used also. In this area we have a "specialty" supply or two that deal in these types of lumber. As stated above, you should check with a lumber yard as opposed to HD or Lowes. It will be less expensive even if it is a special order item....
