Blow In Insulation Question - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-19-2010, 12:02 PM   #1
blow in insulation question
Not sure if this the right category, but I'm remodeling my master bedroom and have insulation questions.
First some background. Older home, 1930 build, meaning-no insulation in the exterior walls. Bedrooms on second story with vinyl siding exterior and plaster/lath interior walls.
The masterbed room is cold in winter and drafty in some spots, so while I am repainting walls, fixing cracks I am considering blowing in insulation to increase the room's comfort. I am thinking of blowing from the inside. I am prepared to do some work on the walls, so the holes don't bother me. However, I don't want to replace all the plaster/lath with drywall.
My questions about blowing insulation revolve around moisture buildup. From what I can tell, there is no moisture barrier under the siding, and obviously by keeping the interior walls, I won't be able to put a moisture barrier under the interior surface.
If I were to blow in cellulose insulation, will that create condensation or moisture issues within the wall? And if so, is there a potential for mold in the cellulose insulation? Is there another insulation material that I should consider?
With my limited knowlege of this type of housing construction, I know that the airflow does a good job of keeping things dry within the walls, but not a good job of keeping the cold air out! And, I don't want to create more problems by adding insulation.
Sorry for the long post. Any advice greatly appreciated. I am considering kicking this part of the project off in a week or so. I may have a contractor handle the insulation, but since it is not a large room I am considering making it a DIY. Just want to be informed either way I go.
Cool user name is offline   Reply With Quote
Old 12-19-2010, 04:32 PM   #2
DIY staff
Rewards Points: 7,174
This is one of those times to call in an insulation contractor----They will likely suggest a low expanding foam----That is a product not available to us lowly DIY types---
The foam will flow past most obstructions -and provide the vapor barrier you need--
Others here might know of a DIY wall fill--so just wait--we will see.--Mike--
Old 12-19-2010, 06:35 PM   #3
Registered User
Rewards Points: 5,236
Where are you located?
Some info on cellulose w/o v.b.: http://www.cellulose.org/HomeOwners/...orBarriers.php
SPF if affordable.
Gary
Old 12-25-2010, 10:20 AM   #4
Moisture Barrier Myth
The idea that you must put a vapor barrier or retarder in every wall has long been discredited. As far back as the late 1970s published studies involving hundreds of homes clearly showed that retrofitting uninsulated homes without vapor barriers with insulation resulted in no moisture problems. Today building science recognizes that in most climate zones a warm-in-winter vapor retarder is more likely to cause problems than to prevent them. If you have water incursion from the exterior, insulation in the cavities may retard the drying process. As you noted, the air that's blowing through the cavities now probably keeps them fairly dry, even if some water is seeping in. The research I mentioned suggests that this is not an endemic problem.
dleaoh is offline   Reply With Quote
Old 12-31-2010, 12:24 AM   #5
In older homes, the multiple layers of paint are adequate enough to serve as a vapor barrier. The purpose is to prevent warm humid interior air from condensing inside the wall.
doitwright is offline   Reply With Quote
Tags
blow in insulation , moisture question
Insulation question Branden Building & Construction 1 08-03-2010 02:02 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 09:14 PM
Insulation question veesubotee HVAC 8 10-11-2009 09:48 PM
Garage insulation question trojanman1 Building & Construction 7 09-16-2009 03:51 PM
rafter insulation question Jeremy Hillary Boob, PhD Building & Construction 7 08-02-2009 09:19 AM
