Blocking In Prefab Wall - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-14-2009, 06:38 PM   #1
Blocking in prefab wall
I at a loss for how to put blocking in these prefabed basement walls, any ideas?
bkeech is offline   Reply With Quote
Old 01-14-2009, 08:23 PM   #2
Rewards Points: 162
Maybe I'm missing something from the picture, but is there any reason you can't nail a 2x6 between the wood studs? Nail through on one side and toenail the other?
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 01-14-2009, 08:27 PM   #3
So the place where I need the blocking is between the prefab studs. They are made out of concrete, and topped with a 3/4 wood strip. I am afraid if I nail into the strip on the side, that I'll split it.
Old 01-17-2009, 09:36 AM   #4
Drywall contractor
Rewards Points: 1,070
Screw them rather than nail them or use a trim nailer with 2-1/2" nails. Use adhesive to secure them to the concrete also. You'd actually be better off framing a regular 2"x4" wall in front of the concrete to allow the use of regular electric boxes,etc. Tear the strips off........
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 01-17-2009, 10:16 AM   #5
K&B Remodeler/Tile Guy
angus242's Avatar
Use pressure treated 2"x8"s between the 2 preformed "studs".
Use the existing access holes to bolt them in.
Now you can add the blocking to the 2x8s.
Angus
My Albums
angus242 is offline   Reply With Quote
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 10:18 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
