Blocking Out Studs On A 45 Degree Corner? - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-28-2010, 08:52 AM   #1
Lost..
Rewards Points: 336
Blocking out studs on a 45 degree corner?
I am going to frame a wall that has a 45 degree turn in it. I've done a 90 degree turn where you would use 3 studs to block it out, but I've never done an angle like this.
I have an illustration of how I think the bottom plate, top plate, and cap are supposed to be cut and placed. I'm not sure if the bottom plate is right though. Is the way I have it drawn correct, or should it be similar to the top plate or cap cuts?
And for the corner studs, how do I block the corner? When the studs run out at the end before the angle starts, the way I'm thinking it's done leaves a void on the outside corner. What is the correct way to block the corner?
J S Machine is offline   Reply With Quote
Old 03-28-2010, 09:02 AM   #2
kwikfishron's Avatar
Rewards Points: 172
You got the plates right.
What does the outside corner get covered with, Drywall? Plywood & Siding?
kwikfishron is online now   Reply With Quote
Old 03-28-2010, 09:05 AM   #3
Lost..
Rewards Points: 336
plywood. probably done as cheaply as possible. I wouldn't be suprised if it is 1/8". Hopefully it will be 1/4", but I'm not sure. I'm sure there will be some sort of corner moulding. It is a partition wall for an office at my work.
Old 03-28-2010, 09:45 AM   #4
jlhaslip's Avatar
Rewards Points: 924
no need to block the corner if the material is stiff enough. 1/2 inch drywall will carry 4 inches easy. 1/4 inch plywood or better should be okay, but here is the layout for a piece of solid blocking to fill the corner cut from a 2 x 4.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is online now   Reply With Quote
Old 03-28-2010, 09:49 AM   #5
Lost..
Rewards Points: 336
So basicly if I feel that the pieces will not be supported by the void I need to fill it somehow. Either by a piece like you have drawn Jlhaslip, or just any piece cut to fit the void..?
Old 03-28-2010, 09:53 AM   #6
miter two 2x6 to make corner
sorry miter wrong word ,rip/chamfer two edges
The older I get the better I was
Old 04-01-2010, 11:32 AM   #7
Old School
Willie T's Avatar
This takes a little more wood, but is a heck of a lot easier.
You run only one piece through your table saw at a 45 degree rip. (Doesn't matter if you are right on the edge or not because this piece has plenty of face showing.)
Then you rip the two 2" pieces for the inside studs. (These DO need to be an honest 2"... and these 2' inside studs will work on a setup like this no matter what the wall corner angle is.)
Nail them together as shown to give two solid, non-twisting and interlocked "T" configurations. (This is especially important on today's extra tall walls.)
The hole you see drilled serves a two-fold purpose........ One hole (as shown) halfway up allows you to insert a fire foam wand in there to squirt a fire blocking. Two holes, one drilled in each of the 2" studs, allows for runnng lateral wires... after which you squirt the fire blocking foam in there.
Blocking out studs on a 45 degree corner?-cut-45-corner.jpg   Blocking out studs on a 45 degree corner?-cut-45-corner-2.jpg   Blocking out studs on a 45 degree corner?-cut-45-corner-3.jpg
Willie T
Old 04-02-2010, 10:55 AM   #8
Rewards Points: 150
Seriously amazed by your time and art skills with your pictures. What do you use to draw these up?
slickgt1 is offline   Reply With Quote
How to add blocking w/ steel or metal studs bergerdude Building & Construction 12 04-30-2013 10:59 AM
Need info on tiling around a 90 degree outside wall corner s38hyler Kitchen & Bath Remodeling 16 02-22-2010 08:43 PM
Installing corner shower on studs? ryanh Plumbing 3 09-29-2009 11:28 AM
Bending EMT conduit around 90 degree corner alvanos Electrical 55 03-12-2009 07:09 PM
22 1/2 degree outside corner Rich Marra Carpentry 2 02-09-2009 10:14 PM
