Bifold Doors -- Non-standard Rough Opening - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-13-2009, 02:01 PM   #1
What's a hammer?
Send a message via ICQ to michelob Send a message via AIM to michelob Send a message via MSN to michelob Send a message via Yahoo to michelob
Exclamation
Bifold doors -- non-standard rough opening
I have an 80 year old house that we are currently remodeling. Due to the placement of the brick flue in the center of the house, my ability to make my rough opening any wider than 58" is not available. Bifold doors come in 48" and 60" sizes. Once I finish out my opening (likely with 1x4) there is NO way that the 60" doors will fit. I can't cut them down, because they will be louvered, as this is a laundry closet. What options do I have available as far as odd width bifold louvered doors? I am at a dead standstill until I can get this problem resolved. HELP!
michelob is offline   Reply With Quote
Old 05-14-2009, 01:45 AM   #2
Rewards Points: 26
I finished off my attic space and since the walls were shorter I had to special order some bi fold doors. I got mine at menards and the price wasn't to bad. If I remember they were about 1 1/2 times the price of in stock doors. I had to have them so not much I could do about price.
ponch37300 is offline   Reply With Quote
Old 05-14-2009, 05:03 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Bi folds can be obtained in almost any size needed.
The difference is that they won't be found in the door "aisles" of the Big Home Improvement Stores. What you can do is figure out your rough opening, and take that to a Big Home Improvement store, and talk to someone at the "Pro Desk", or "Mill Dept". Expect to pay approximately double of what a similar style bi-fold door set costs (standard size off the shelf). The doors would be ordered, with a small waiting time.
- Build Well -
Old 05-16-2009, 05:08 PM   #4
Drywall contractor
Rewards Points: 1,070
Use a 24" and a 30" to net you a 54" door. Frame your opening down to suit the door size. Might look a bit "unusual", but will save you the expense of "special order".....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 05-16-2009, 09:47 PM   #5
Registered User
Rewards Points: 526
Better check dryer door to open............. Be safe, G
Old 05-18-2009, 11:19 PM   #6
You could off set the tracks then they will look like bypass doors but will still open like reg bi-fold . I just had the same problem and that is how I did mine.
tybeeanna is offline   Reply With Quote
bifold doors larry58 Remodeling 4 05-12-2009 05:58 AM
Rough opening for bi-fold doors DCCook Building & Construction 6 03-20-2009 09:25 PM
Help installing bifold doors MT Stringer Carpentry 5 11-05-2008 10:24 PM
rough opening for glass block oxicottin Remodeling 5 05-04-2008 08:01 PM
Closet Doors for non standard closet dimensions jherschel Carpentry 7 02-22-2008 04:45 PM
