Bifold Doors - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-10-2009, 11:35 AM   #1
bifold doors
I want to install (2) 24" bifold doors side by side. What is the size of the rough opening? I will be finishing with halh inch sheetrock. Also is there anything between the doors? I guess its called a mullian. Thanks for your help
larry58 is offline   Reply With Quote
Old 05-10-2009, 02:09 PM   #2
Rewards Points: 5,336
Buy the doors first, then build the rough opening for the set. On the packaging it will state the finished opening needed for the doors sizes you want.
There is no mullion. If the space near the jambs are more then you like, you can install a narrow stop molding to close the space.
Ron
Old 05-10-2009, 05:50 PM   #3
bifold doors
already got the doors. no instructions. do the two doors go side by side? they r 47 inches wide, so my rough opening should b 47 inches for the doors plus an inch for half in sheetrock
Old 05-10-2009, 11:26 PM   #4
You will need a finished opening of 48". Doors are side by side, hinged in the middle.
Mop in Hand is offline   Reply With Quote
Old 05-12-2009, 06:58 AM   #5
Man of many hats
wrangler's Avatar
Rewards Points: 354
I just installed a set on Saturday (along with 12 slab panels, a pocket door and 1 prehung!) and the finished size for the set of doors I had required 47 1/2". 48" would works as well, you'll just have a slightly larger gap clearance on the outside edges.
Man of many hats
wrangler is offline   Reply With Quote
bifold doors larry58 Carpentry 3 05-02-2009 02:30 PM
Bifold doors driving me crazy! Gevans17 Carpentry 8 01-29-2009 05:12 PM
Help installing bifold doors MT Stringer Carpentry 5 11-05-2008 11:24 PM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 06:04 PM
Bifold Laundry Closet Doors? DIYtestdummy Remodeling 2 02-14-2008 03:38 PM
