Best Way To Remove Cement Backer Board? - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-01-2011, 02:34 AM   #1
Best way to remove cement backer board?
Screw heads are stuffed with caulking and cannot unscrew. What is the best approach to take down backer boards?
shilpa is offline   Reply With Quote
Old 10-01-2011, 06:38 AM   #2
crow bar/wonder bar, elbow grease!!!
Old 10-01-2011, 06:55 AM   #3
Rewards Points: 150
No matter what kind of caulk it is you should be able to drive a bit into the screw head. Or try to remove the caulk with a razor knife. It will save alot of time.
OhioHomeDoctor is offline   Reply With Quote
Old 10-01-2011, 03:53 PM   #4
Rewards Points: 5,336
I'm confused by the issue. Why was caulking put on this? Are you sure it's not thinset?
As previously stated, a metal bit should be able to be inserted into phillips head screw.
Why do you need to remove the board?
Ron
B. Franklin 1759
Cement Board Questions trophywalleye Drywall & Plaster 17 06-29-2011 10:56 PM
Remodeling bathroom - question regarding cement board prontocruz Building & Construction 2 06-27-2011 06:11 PM
cement board flex (a bit) rtoni Building & Construction 2 12-16-2010 02:01 PM
cement board install billyg Flooring 2 07-10-2009 12:52 PM
Hardie backer board DXS General DIY Discussions 2 03-17-2009 05:40 PM
