-   -   Best way to remove cement backer board? (http://www.diychatroom.com/f15/best-way-remove-cement-backer-board-118829/)
shilpa 10-01-2011 03:34 AM
Screw heads are stuffed with caulking and cannot unscrew. What is the best approach to take down backer boards?
Just Bill 10-01-2011 07:38 AM
crow bar/wonder bar, elbow grease!!!
OhioHomeDoctor 10-01-2011 07:55 AM
No matter what kind of caulk it is you should be able to drive a bit into the screw head. Or try to remove the caulk with a razor knife. It will save alot of time.
Ron6519 10-01-2011 04:53 PM
I'm confused by the issue. Why was caulking put on this? Are you sure it's not thinset?
As previously stated, a metal bit should be able to be inserted into phillips head screw.
Why do you need to remove the board?
