Best Way To Lay Tile On Fireplace? - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-18-2013, 11:18 PM   #1
Rewards Points: 87
Best way to lay tile on fireplace?
Hi all. I am wanting to tile my fireplace with some of that slick high quality grey tile. The tile has a high gloss finish on it. But What is the best way to do the transition from the flat, horizontal surface, to the vertical surface where the brick meets the wood floor? I don't really know how to do the corner there. I don't really want some thick grout line, or the unpolished surface of the side of the tile showing. But I'm trying to keep it all flat. See the pic for what I'm talking about.
Bennylava is offline   Reply With Quote
Old 09-18-2013, 11:28 PM   #2
Rewards Points: 12,876
Baseboard or bull nose tile should work.
http://www.bing.com/images/search?q=...ectedIndex=105
Old 09-19-2013, 06:54 AM   #3
DIY staff
Rewards Points: 7,174
If the tile is solid porcelane the edge can be polished or even bull nosed---my local tile supplier provides that service.
A long mitered edge is possible--if you have the use of a bridge saw it is rather easy.
Old 09-20-2013, 03:23 PM   #4
Rewards Points: 87
So I need to get porcelain so that the edges can be polished. Also, what exactly is bull-nosed? I have never heard of it.
Old 09-20-2013, 03:27 PM   #5
DIY staff
Most tile is just a colored glaze on the top with a different colored body---the edges look ugly----
Solid body porcelain is not glazed--the material is the same color all the way through--much like granite---those can be polished ,by a shop that has the right equipment---
Old 09-20-2013, 07:03 PM   #6
Rewards Points: 87
Thank you very much for the helpful replies. Would you say that this is the preferred method of making the corners look good? How would the pro's do it?
Old 09-20-2013, 09:12 PM   #7
DIY staff
I have a bridge saw ---so I do a lot of mitered corners----it is expensive to have porcelain tile or granite bull nosed and polished---so I seldom get that done.
Many tile have matching bull nose---so that is an option also.
Old 09-20-2013, 09:14 PM   #8
DIY staff
Marble is soft enough to bull nose your self using a belt sander and a buffing pad in an angle grinder-----I bull nose a lot of marble----
Old 09-21-2013, 06:22 PM   #9
Rewards Points: 87
Anyone happen to have a pic of a bullnosed piece?
Old 09-21-2013, 07:31 PM   #10
DIY staff
ceramic tile bullnose - Bing Images
can you tile over tile around a fireplace three5311@live Tiling, ceramics, marble 1 02-10-2013 01:12 PM
Tile and wood over painted brick fireplace OddBuffalo Concrete, Stone & Masonry 0 08-17-2012 09:15 AM
Framing tile fireplace with hardwood how do you determine the cut/angle? pbthompson3168 Flooring 9 08-12-2012 07:55 AM
Tile in front of fireplace with carpet - new addition midi77 Flooring 3 11-12-2011 12:29 AM
OK to tile over vent/gaps on brick fireplace? roxksears Remodeling 4 01-22-2010 01:48 AM
