The last link has 1-1/2" length between each "cross-beams" where fire can travel to the walls. Check this from another moderator; second pic in post 12, post 22;
How to fireblock framing
2. Need canned foam/caulking
under foam panel (imperative to air seal), glue pattern
behind it is also very important;
http://joneakes.com/jons-fixit-database/743
2-1/2. Add foamboard to top edge of concrete wall (all surfaces of the concrete "sponge";
http://www.buildingscience.com/docum...ce-insulation/
3. Add a sill sealer under all bottom plates for an air/thermal/capillary break, whether a poly plastic is under the slab or not;
http://www.greenbuildingadvisor.com/...-building-code
3-1/2. ADA the drywall to stop air from getting to the cavity insulation/concrete wall though pin-holes you may have missed to condense basement moisture on the wood framing if the foamboard isn't thick enough or holes in foam seal,
or around electrical boxes;
http://www.buildingscience.com/docum...wall-approach/
4. Use nailers along running joists every
2', not 3' on center per drywall manufacturer if the next joist is farther than 7" from wall. Never nail
through a chord of an engineered joist, always toe-nail blocking to the chord, risk splitting the 1-1/2" ones. I posted that in this forum some time ago, no search tonight. I was nice; double-up on some and counted funny, they must feel bad enough...
Gary
P.S. Don't forget your basement egress windows per code to keep everyone safe.
